Correct me if im wrong
I have been reading about how some of you have problems with high current draws when switching on electric fans,this might help.
What if you were to put 2 12v light bulbs inline with the fans.When you turn the fans on the lights will take up the high current then when the fans get spinning the lights will still stay on but the fans would work as usual also.
When the fans arn't spinning at startup its like having a short in the system,but having the lights in there will take up the initial "shock".They will glow bright at startup then dim once the fans are going.
Its kinda like a "cusion" for the relays and fans.
If someone has already thought of this,sorry for the "New Idea"
