Where can you read this paper?
When I bought my parts from Strange I saw they had a non-crush sleeve but they said it was just for racing and talked me out of it. How many of you guys are using them for street?
Solid sleeves are NOT just for racing. 4 wheel drive vehicles need them for off road to prevent the backing off of the pinion nut when going DOWN hill, Toyota uses them in all rearends.
Believe me they are easier to use then a crush sleeve, they never ever back off the preload on the pinion nut and they really make setting up the pinion so much easier.
I personally make them myself. I have a heavy walled piece of pipe and cut and machine custom spacers to length all the time for any rearends I set up.
Gary and really great guy at doing custom rearends sells the shimmable kind. I will try and find his paper and post it here to all to read. Remember his specializes in corvettes but setting up a rearend for anything is all the same. He particularly does great work on setting up the posi units and the axle gears or side gears.
