Howdy!
Two things are going on and I'm feeling like they're connected. Can someone help?
First of all coolant is dripping steady from just rear of the passenger side front wheel well. Directly off the body mount bolt down there. I can't find the source, or even a coolant line nearby. I should add that the leak doesn't seem to happen at idle, but flows once I turn off the engine.
Secondly, since I noticed the leak I've also noticed the transmission beginning to make a whirring noise at idle in Drive. Shifts seem to be off, or slow and clunking into gear when I manually shift from L to D. Checked trans fluid, it's full/okay and clean.
My suspicion is that coolant is not getting to the tranny and the old Powerglide is overheating. I've check the fittings at the trans and radiatior, they are dry and snug. I've inspected the lines and all looks good / dry.
Any thoughts?
Daily driver, 67 Malibu / 327 /2bbl Rochester / Powerglide / AC.
Any thoughts?
