Hello. I am in the process of working my way through a manual to power steering upgrade. My engine is a 283 with short water pump. From the way things are going, it looks like I will need to swap my 2 track crank pulley for a 3 track to make the alignment work. I have an old assembly manual, and it looks like the outer most track is for the power steering belt, but it looks smaller in diameter than the inner two tracks. Is this true? Does the crank pulley diameter have to be kept equal to the power steering pump pulley diameter to maintain a 1:1 ratio? Need to know this before I begin my crank pulley hunt.
Thanks in advance, Bill
