Looks like I may need a vac system for the high compression 496. I have been losing oil out the back of the engine so I replaced the valve cover gaskets and installed 4 cotton open filters in the valve covers. I thought I had the the crank pressure and oil leak solved, but I think its now leaking out the back of the intake manifold.
Do I have any other options besides a vacuum pump? Anyone having any luck with an electric pump? By the way, the motor is a fresh build and I did not use gapless or low tension rings. Thanks for your ideas.
