1 - 10 of 10 Posts
My Baltimore built 70 SS was originally Champaigne Gold, now Cranberry Red (like so many others). I'm curious as to the color of the Lower Cowl just under the windshield and the Fender Tie Brace (believe thats what its called just in front of the Radiator Support). Seem just about on all cars I've seen they are black, which mine is as well. However, some of my black paint is chipping in the corners and I can see the original Champaigne Gold peaking through. Where those areas originally painted the color of the body or were they stock black? Not sure why I would have gold there.
Thanks,
Dave
* frame and upper/lower control arms and upper shafts-semigloss black
* front coil springs-gloss black or natural(better detail contrast)
* firewall, inner fenders, radiator support-semigloss black
* radiator and fan-gloss black
* fan clutch-natural aluminum
* radiator shroud-natural black plastic or gloss black
* steering box-natural cast iron gray
* steering linkage-natural steel
* front sway bar-natural cast iron gray
* heater or AC housing-semigloss black
* hood hinges, latch, catch and springs- gray phosphate plated
* brackets and steel pulleys-semi gloss or gloss black(gloss gives more detail contrast)
* cast iron pulleys- natural cast iron
* master cylinder- natural cast iron(some use gloss black)
* brake booster-gold cadmium plated(master cylinder lid also)
* windshield wiper motor-gloss black
* alternator- natural aluminum
* power steering pump-gloss black
* AC compressor-semigloss black
* steering column shaft-natural steel
* horns- gloss black
* coil- gloss black
* voltage regulator-gloss black
* distributor- natural aluminum with gloss black cap
* fuel and brake lines-natural steel
Thanks, that's what I thought ... my gold on the cowl area and fender brace must of been from a bad repaint back in the day.
Thanks again.
Great info but dont see the Cowl Area or the Fender Tie Brace on the list.
The firewall and cowl is the same.
Mickey, the car on the right side does it even have wheels on it???:D
It sure is sitting LOW:D
1 - 10 of 10 Posts
