First of all, what parts do you have? Once it is known what parts you have, then we can let you know what you need.
Next, to specifically answer your question, YES, the outside flapper door can easily be made to work totally independant of whatever you have for an air cleaner----------------but first we gotta know what parts you already have.
I have a different check valve in the vacuum line on our 70, so the flapper on ours closes a little more slowly than they did from the factory. Under hard acceleration, the door should open quickly, then close somewhat slowly when vacuum increases.
Here is how ours works.
