I'm completely restoring my cowl induction system as part of my engine resto and there is one part I cannot find mention of anywhere in our catalogs - and being a purist I want the correct part. There is some type of screw which holds the outer cowl door to the vacuum actuator pod. None of the catalogs, YearOne, GroundUp, NPD, OPG, etc. make any mention of this "screw". When I asked our sponsor they assured me it was the same shoulder bolt as is used for the outer door hinges (the ones with the nylon bushing) but this is incorrect as the diameter of the hole in the outer door isn't wide enough. Can anyone help??? I can easily rig it with a pin screw but I know its not correct. Thanks in advance if you can answer this!
Stan Hanek
'71 SS - 454 4 sp.
http://www.chevelles.com/showroom/stan71delivery.jpg
Just checked my Classic Muscle(Modern Chevrolet)catalog(800-722-4828) and if I understand you right their part # for the screw is 3922128 but can not be bought seperatly, it comes with the vacuum actuator assembly their pn# 1998970,for $29.95.
Elcaminos are special!
I'd rather walk around with a Chevrolet hubcap in my hand than drive a Ford
work in progress
Big James Elky(AKA Ol Paint)
another shot of Ol Paint
Thanks, James. That is the correct part number - I found it in the Factory Assembly Manual after my post last night. I'll give them a call ... the manual shows an actuator with a different style rod than I have seen before. I don't know if the diagram is correct or if the pod I have (appears original) is the correct one. I'll give Classic Muscle a call tomorrow and see if they might break a kit for me. Thanks again!
Stan Hanek
'71 SS - 454 4 sp.
hey stan, Nice 71, it looks exactly like my 72, Ill send a pic.
I used a screw with the same thread size, i'm not sure if it is correct but it works fine and you dont see it.
Jeff litka
72 chevelle SS
72 Montecarlo
[This message has been edited by JSL (edited 02-18-2001).]
