Counting Teeth? - Rear end ratio?
1791 Views 3 Replies 4 Participants Last post by  Fred Aldrich
I am interested to find out if there are a set # of teeth on the ring gear for each of the different ratios? If there is, does anyone know the teeth # for the popular ratio's, or is there a formula to calculate it with?
Divide ring gear tooth count by pinion gear tooth count to figure out gear ratio.
Check out a hi-perf/race catalog such as Jegs. They provide tooth counts with the ratios in their rear-end section.
It's usually possible to "guess" the tooth count by examining the fractional component of the ratio. For example:
the reciprocal of .07 is 14 so a 3.07 must be a 43/14
3.08 is 37/12 or 40/13
3.31 is 42/13
I'll work up a simple table and post at my web site www.GeoCities.com/~68_chevelle in the next couble of days.
