Can I use a 68 BB corvette oil pan in my 67 Chevelle? I have SB mounts if it matters. Thanks Don
D don · Registered Joined Aug 31, 1998 · 79 Posts Discussion Starter • #1 • May 26, 1999 Can I use a 68 BB corvette oil pan in my 67 Chevelle? I have SB mounts if it matters. Thanks Don
DZAUTO · Registered Joined Sep 29, 1998 · 13,015 Posts #2 • May 26, 1999 Is the bottom of the pan flat where it goes over the front cross member? If so, yes. If it is rounded, no. ------------------
K Kevin · Registered Joined Sep 15, 1998 · 246 Posts #3 • May 26, 1999 I couldn't use one in my '71 because the sump is too long. I don't think the 67 K-frame is that much different.
DZAUTO · Registered Joined Sep 29, 1998 · 13,015 Posts #4 • May 26, 1999 Yes, I'm sure you are probably right. Although, BB pans should be fairly easy to find and very reasonably priced. ------------------
DZAUTO · Registered Joined Sep 29, 1998 · 13,015 Posts #5 • May 27, 1999 Don, I was just over in the Parts For Sale section and saw an ad for a BB pan. The ad was titled "Parts Parts Parts" and it was posted Wed May 26. [This message has been edited by DZAUTO (edited 05-27-99).]
