I need to get the correct valve cover grommets for my 350. Where can I get the correct ones? The one on the right side valve cover shouldn't be that hard to find but where can I get the slanted type PCV grommet for the left side?? Please help soon. I just painted my covers and I'm anxious to get them back on. My engine info is listed in my signature below. Thanks!
1970 Chevy Custom El Camino aka Kaileigh
Green Mist & Silver w/Green Vinyl Top
350ci/300HP 4bbl & Factory Dual Exhaust
Non-SS with Factory Rallies!
TH-350 Automatic - 2.73 Posi Rear
My El Camino Home Page - www.dreamelectric.com
You really think that my local auto parts store will have them and they would look original? That'd be great. I also need the cork gaskets. I wasn't sure about getting their parts because I got a thermostat from them but it's the wrong temperature for my engine.
I have another question, the long washers on the valve covers are arched in the middle. Should the arch be facing up or down (towards the valve cover)?
[This message has been edited by Shawn (edited 02-08-2000).]
Shawn,
When you say long washers, are talking about 3 inches long, if so they are aftermarket, the hump goes up, away from the valve cover. this lets the outside edges hold pressure on the gasket, not the bolt. The orginal washers are about 1 to 1-1/2 inches long, and are flat.
