1 - 17 of 17 Posts
Are you running a manual transmission. If so you are good to go...If not and running an Automatic ... depending on which Trans you are running you may need a Tee type of fitting with a large hose end for the Brake booster and a smaller hose end for the Trans Kick down vacuum line. A 2 speed Power Glide and 3 speed Turbo Hydromantic 350 requires this. If running a TH400 it is electric... again no need for the tee fitting. If running a newer type of trans it may need this...I am not sure Probably electric computerized etc...
Good luck!
Capt Casey said…”A 2 speed Power Glide and 3 speed Turbo Hydromantic 350 requires this. If running a TH400 it is electric”. Now I’m confused. Been a while since I’ve been under my car but I think my T400 has a modulator with a vacuum port.
1 - 17 of 17 Posts
