I have a 65 with a 350 crate motor. I have installed a gm serpentine drive system and I am now considering the options a cooling fan. I have the original 4 core radiator. I would be able to mount a conventional clutch fan if I deleted the spacer shroud between the radiator support and the radiator, but I have also considered going the electric fan route. What are you guys running and how do they work? What would you suggest?
What kind of electric will be big enough? Will a single 18" fan do it? Or should I be looking at a dual setup? I have A/C.
65 Danube Blue 4 door wagon, Factory air, am/fm stereo.
The Flex-a-lite dual 12" puller fan system is outright incredible. It has a flexible weatherstripping that seals to the radiator around the built in shroud. It is a near perfect fit for 68-72's and may be for other years but I am not sure of other radiator sizes. I use one on my Monte and couldn't be happier with it's performance.
Also, now without the huge shroud, I can stand on the ground in between the radiator and the water pump while working in the motor...ha ha
'71 468 Monte Carlo Street/Strip
11.55 @ 116.6
1.62 60'
Where can you get the Flexalite fan setup? I don't see it in Summit. Any other mail order cats have it?
JimN, I think that's the one I've got sitting in my garage (Summit should have it if you call, that's where I got it. Check under the Black Magic line, I think)- you are welcome to it if you want, I was going to hang on to it in case I ever decided to use it, but I want the stock look so it won't be anytime soon. (had it as a backup on an overheating daily driver)
It is an incredible fan, pulls tons of air. 2 fans and a rubber seal around it that keeps it snug, and it has a thermostat control to raise/lower it's starting point. Only downside is the thermostat goes inside the upper tube, I know you could buy one that clips inside the radiator fins.
As cperril said, it does draw the amps - this one pulls 20 amps. Email me if interested.
