Guys,
I've read about similar problems people have had here, but here's my problem.
I'm leaking small amounts of coolant at a few lower stud head bolts - checked the oil and it appears free of coolant so far.
So here's the question: I've got head studs, so how do I remove the lower studs since I don't think I can use 2 nuts to back them out?
Or should I first try to use stop leak or those GM pellets?
Small block 383, aluminum heads, good fel-pro head gaskets
thanks for the suggestions!
