Is it possible to modify a steering column that was originally set up for a column shift to be a floor shift column by just taking the parts out of it? I realize you would still have the whole where the shifter arm exited the column. As you've geussed at this point I have a column shift that's going in a floor shift car.
Lance
Depending on the year, I don't think you even have to remove the internals...
You can cut off the bump where the shifter attached, and either weld a piece in, or try to Bondo it closed...
Maybe some of the later Chevelles might have a problem with the ignition switch, as I think there is linkage that will not allow the key to turn unless in a certain gear (Park, Neutral for and Auto, maybe Reverse for a stick?)...
"Once you go RAT, you never go back..."
TC #1366
Tony
http://www.chevelles.com/showroom/Quik66.jpg
http://www.chevelles.com/showroom/eng7.jpg
