Hi,
I'm to the point of installing the "wire on" over the staples on the rear bow. How does that thing work? staple it down and just bend it rearward? Thanks,
Les
Hello Les,
You are correct. Once you have the strip lined up where you want it, staple it, then fold back. After folding it over on my car, I installed the stainless "end-caps" with small nails to hold the strip down on each end. I drove the nails directly through the the last 1/8 inch of the strip, which gets covered by the end-caps.
Good luck, Joe.
From the "For what it's worth" dept: Don't make the wire-on too long, as these tops need as much looseness to fold properly as possible. I cut mine @6.5" past the heat-sealed seam (9.5" up from the stainless belt rail mldg), looks good but the wire-on ends still tend to lift (screwed mine on) after awhile. I wouldn't go any longer.
Rich
