1 - 1 of 1 Posts
I have a 1968 Chevelle convertible the top is in good shape however I have a question regarding the top pads on the inside. Are these supposed to be at ached to the top by where the sun visors are. Mine are not an than sometimes fall unless they are jammed in between the handles on either side. The bars they go across hold them up but from the last bar to the very front of the top there is nothing to hold them? They just hand and sometimes fall and smack you in the head.
Also anyone know of where the bolts or adjustment points are to adjust the top.aligment of the top. (mine still folds down with no info) Mine blew up in the wind a while back and seems lightly bent it goes a little to far forward (hanging over chrome) when you are trying to close it. However before the incident it would be a little short and you would have to pull it forward so It might have almost helped. But personally I would like it to be perfectly lined up when I push the button to close it. Thanks for your help
If any pics are needed I will be happy to post them
1 - 1 of 1 Posts
