Hello, I'm converting 69 automatic from column to console. The shifter has a neutral safety switch. Do I remove the wires from the NS switch on the column and redirect them with jumper wires to the console's switch? Or can I just tap (with one of those T-shaped crimp-on connectors) into each wire, leaving the column NS switch intact?
I'm not going to replace the column right now, and I'd like to maintain the safety switch, as well as the column key-locking feature and the back-up lamps. Thanks.
John
There are wiring harnesses available to wire into the console. It comes with the console lighting circuit and the NS and Bu switch connections. Check with any of the parts suppliers. Its an easy wiring job, harness was a little spendy imo though.
Rob
For about $40 there is a "Console Ext. Harness" for 69-72 with Auto trans. This harness will plug into your existing wiring harness under the dash. Then the other end plugs into your console harness. Keeps everything neat and clean with solid connections.
Otherwise you can splice all you want.
