1 - 10 of 10 Posts
Back-up lights connector. Needs to connect to the neutral safety switch. Pink= ignition hot, light green=out to rear of car.
Thank you...Will just need to find the other end where it plugs in to..
(For 1970) For column shift automatic (or 4 speed manual on the floor), check the top side of the steering column assembly where it meets the firewall. For automatic in the console, the neutral safety is inside the console linked to an extension harness that pops out around the where the "floor hump" meets the firewall.
1 - 10 of 10 Posts
