Fellas -
Did a few searches and found some info on setting up hard lines in a shop/garage from the compressor to the tool end. My problem is that I'm active duty military, and will only be here for 1-3 more years, so I'm not inclined to plumb the garage with hard lines.
My setup right now is a 33 gallon 6 hp Sears compressor and the flexible rubber hose. I use it to run air tools, blast cabinet, and may try to paint with it, too. Right now, the water in the line does slow down the blasting process a bit.
Any info/ideas on where/how to minimize moisture in the rubber line?
Thanks!
Scott
Thanks!
Scott
