Compressor questions
1587 6
My compressor had a bad day a few weeks ago (got smashed between 2 cars), and I'm looking for a new one. The old one was a 3 HP portable and was OK for small jobs. I'm looking to do some more extensive work and was wanting some opinions on what you folks are using. I want to be able to use normal air tools and also paint with it. Do I also need an automatic oiler, water trap, etc???Thanks in advance.
Jake
Member#354
66El Camino(In progress)
64 Malibu
Stafford County, VA
Administrator
Jake, I'm using a 6 hp, 60 gal vertical tank, single stage Campbell Hausefield and so far it does well. It runs all my air tools, even the DA sander. I live at 7000' so performance is less than lower elevations. I bought it at Home Depot 2 years ago for around $350.
Philip Valentine
Lakeside, AZ
Team Chevelle Member #42 GOLD
[email protected]
i have the a portable one from ears, 5.5 hp and a 30 gallon tank works great but havn't tried painting with it i doubt if i could paint a car without stopping everyonce in a while for more air, the air ratchet on 100 psi works great and has never failed, impact too.
OWNER OF 66 CHEVELLE MALIBU
Check out page dedicated to resto of my chevelle. still being made.
www.geocities.com/MotorCity/Shop/9801/
Team Chevelle # 424
Canadian Classics Chevelles and Beaumonts #393
I just purchased the 6/60 Campbell Hausefield from Post Tool here in Calif. $397.00. No oiler, or electrical plug. BTW its 240 volts.
So with wire , block valve, fittings and regulator/water knockout I've got about $500.00 in it.
Its a good unit, not real loud either.
Lynn Robinson
Pacheco, Calif.
64 Malibu SS, 71 Camaro SS
"Just Hit the Ball and Touch em All"
Team Chevelle Member #246
[This message has been edited by Coach (edited 10-22-99).]
Painting a car doesn't take that much out of your air compressor. Now sandblasting...that requires alot of air. As does a good bit of air tools like impact wrenches, sanders, etc. They like alot of air too.
In this case, bigger is better. Get the most you can afford.
Bob (Pa.)
1963 Impala 283
1966 Chevelle SS 409
1969 Malibu 307
1972 Malibu 307
1969 Chevy stepside 350
Bob's 409 Chevy Page
silverstone.fortunecity.com/tvr/246/bob_s_409_chevy_page_index.html
If you do a lot of work with an air sander or painting then a two stage air compressor is best. However, you can get by with a single stage by reducing the length of time you stay 'on the air'. The two stage has a quicker recovery than a single. Sanders die out quicker w/single stage. I have an 80gal single that works quite well due to the large capacity.
Auto oiler...NO-NO-NO!!! Especially if you plan on painting. Oil will get in the air lines. Oil your tools not the line.
Painting...Air drier & water trap will be needed. I mounted mine at the compressor. You'll always have minor air leaks. Install a Gate Valve on the compressor to prevent it from going off & on all the time while your away. It's not good for the tank to expand & contract from empty to full all the time. It'll still leak-down even if you flip the power off.
Simply shuting it off won't work because air will always leak
Lowered '67 Elcamino
ZZ430 eng / 4L60E trans
"Canyon Carver"
Susp: Neg. Roll
