Folks
I am in need of a pump for a stand up compressor that someone gave me. I am leaning towards a 3 cylinder single stage from Eaton Compressors. Does anyone know anything about these guys. They state that they are all cast IRon and they do have a 5 year waranty.
Any insight that anyone might have would be appreciated
I would talk to Eaton on what you propose to do, they should have some pretty good answers.
Do you know what kind of shape the tank is in, is it safe enough to take the pressure, also you could have problems with oil or rust shale in it.
Tell Eaton what you have, its probably okay, but its better to check it out.
If Eaton won't work with you, try Quincy or somebody else, but I would definitely talk to somebody in the compressor business.
Rob
Thanks Rob
Tank is clean. This unit is only a year and a half old. They ran it with out oil to blew the pump.
I had spoken with them quickly and they had recommended the 3 cyl single stage.
I just wanted to see if anyone had dealt with them.
