I finally got around to doing the comp. check on my engine (using oil/smoke when you get on it hard). Dry the reading for all 8 cyls. was 180psi +/- 5 psi. With a squirt of oil each cylinder(all 8) rose to 240psi. Now my deduction is even after 3000 mile my rings(moly) have not seated. Is this possible? I ran Valvoline 10w-40 changed @break in,100 miles, 500 miles,1000 miles. At 2000 miles I switched to 20w-50. Am I missing somethig here? Any ideas? Also the plugs AC/Delco rapid fire #4's look fine. Thanks for any suggestions. If I pull its getting a stroker kit(496)......
Jeff ACES#841 TCG#158
68 SS396(454)
68 L78 Project
87 MC SS
68 SS396(454)
68 L78 Project
87 MC SS
