I've entered my complete engine plan, including head flow numbers, into this program from comp cams called Cam Quest 6. Here it is:
496 big block
Patriot Performance Heads 320cc
Comp Cams Hydraulic roller, .612/.612 lift, 244 dur @ .050 and 110 LSA
10.1:1 comp
Performer RPM Air gap
Demon 850 cfm carb
Results from this program say 695 hp and 650 ft/lbs. Based on other builds I see, cam specs, compression etc. This seems to be an exaggeration. I estimate it around the low 600 to 650 range.
Does anyone think this type of power is available from this buildup?
Does anyone have a program that can give realistic power output based on the above info?
Thanks,
Josh
496 big block
10.1:1 comp
Demon 850 cfm carb
Thanks,
Josh
