just ordered a set of the patriot aluminum bbc heads and a Howards hyd roller cam 222/234 .577/.579 on 112. 9.5 to 1, 502. wanting a torque monster for a 63 vette with a 4 speed.
IMO, If you want a torque monster, this combo is a little bit of a mis-match. Big port heads that will carry that motor to at least 7k rpms but a cam that will give out around 5500.just ordered a set of the patriot aluminum bbc heads and a Howards hyd roller cam 222/234 .577/.579 on 112. 9.5 to 1, 502. wanting a torque monster for a 63 vette with a 4 speed.
Kettbo has it right.... more lift & duration and spin it higher. Makes for a better combination for a Corvette. :thumbsup:you do not need any torque, you'll never get it to the ground
go 10 or more deg dur both intake and ext
I would have to agree here......I only have a 305cc head on my 496 that turns 7k.IMO, If you want a torque monster, this combo is a little bit of a mis-match. Big port heads that will carry that motor to at least 7k rpms but a cam that will give out around 5500.
I think you would have been better served by using a set of oval port heads. Brodix Race Rites if you want aftermarket alloy heads or a set of 049 or 781's reworked with bigger valves and bowl porting. This is just my opinion.![]()
