Ok, I did a search on the topic first and came up with nothing to answer my specific question.
I am converting a 72 column shift to a console shift. I have the console, shifter and nuetral safety switch. I am not going to swap out columns just yet.
Anyhow, I want to re-wire the console nuetral/reverse lights safety switch on the console so that everything works correctly. I know that I can go buy the console harness and make life very simple, but I would rather just make a harness. (I already made one for the shift indicator back lighting and the courtesy light at the rear of the console.)
Anyone else done this same thing? Any pointers or wiring diagram/description would be appreciated.
http://community.webshots.com/user/moabdad The reason for muscle cars & big trucks is for the power. Here is the theory I used: Power=Good
I just did this same job on my '72. The nuetral/reverse light switch is on the column with mine and is operated by the shifter lock rod which turns the lower part of the column when you move the shifter. All I had to do was to swap the column and plug in the existing wiring. The floor shift column I have was from a '72 as well so it has to be correct.
The only wiring for the console would be for the lights.
Bob (Pa.)
1963 Impala 283
1966 Chevelle SS 409
1969 Malibu 307
1972 Malibu 307
1969 C10 stepside 350
1971 Cheyenne 20 3/4 ton
Somebody stop me... :)
Chevelle parts for sale
The 348/409 Chevrolet forum
http://www.network54.com/Hide/Forum/187005
Louie, My wife gave me that name because I take the family vacation every year in Moab, Utah for the Easter Jeep Safari........ Is there some sort of a connection to DUNE? I have never seen the movie.
I did the same, converted from colume to floor. I some what new to this aspect so please bare with me. Thanks in advance.
Question, I am replacing the old shift sleve and need to know how to override (if thats what you do) the netural safty switch ? in the key lock. When I try to turn the key on it wont turn unless I jiggle the starter rod?
any help would be appreciated. Now I know why Inever did stearing wheels!!!!
