is there enough throw for a column shift to work for a 4 spd auto, like a 4l60, or 4l80e? i thought someone had done this once
There is enough throw but you may need some adjustment help with a lokar shift arm from the tranny to the shift arm on the column which is adjustable for the positions.
I did this in my red 70 SS 454 wagon. I have a 700R4. I used the shift arm from the 350 bolted it to the 700. I had to tweek the floor boards about 1/8--1/4" to let it go down into first. Very E-Z to use all the stock parts. D-is O.D. and so on. This was a easy swap and the Nut. Safety switch never touched it, Back up switch, never touched it. Every thing works well. Bob
ACES AACA
Also the 350 Cooler lines bolted right up to the 700 no brainer. The T.V. cable, I used the 350 kick down brkt. (same size hole).
