Hi All, I am curious about the voltage on my coil. When the ignition switch is in the "ON" position I have 5.8 volts. I've heard 8 or 9 volts is more normal, but it seems to run OK. When I turn to the "Start" position I get the full starting voltage of approx 10.5 (as the 2nd wire on the coil is off of the starting solenoid). What confuses me is that after the car starts and the ignition switch returns to the "ON" position I still have full battery voltage of now about 13.5. I don't understand what is feeding this voltage to the coil. There should not be any feed to the starting solenoid when the key is returned to the "ON" positon from the "Start" position. Any suggestions as to where to look is appreciated. It would seem like this higher voltage is hard on the points? I do get a weak looking spark, maybe I should go with a 12 volt "high-voltage" ignition system?
thx much!!
Larry
thx much!!
Larry
