Hello everyone, I spent the holiday morning investigating a bad front-end squeak caused by the coil-over shock upper shaft rubbing on the hole where it passes through the frame. I removed the QA1 coil-over shock and spring and found the factory shock mount hole is not centered in the upper spring pocket. The shock tube was rubbing a groove into the frame to find the new center point. I fear the twist on the shock tube will cause the seal to wear and leak. This must happen with other Chevelles who installed coil-over shocks.
My question is what would you recommend? Should I drill a new hole for the shock to pass through the frame at the center of the spring pocket, and weld closed the offset factory hole?
You can see in the photo that the factory hole for the shock to pass through is nowhere near the center of the spring marked in red. This was okay with separate spring and shock the way the factory designed it. Now with the coil-over the spring determines where the shock is located.
I would appreciate any advice. Thank you.
