1 - 8 of 8 Posts
I replaced a clutch fork (GM 1964 and up) purchased from Ground Up on my 1969 Chevelle. The original clutch fork worked fine prior to the change. I am not too sure what type of clutch fork I originally had before the change. But the one that I purchased is different. Now the clutch appears to be engaged all the time. I can go through the gears without the clutch engaged. I had to adjust the clutch fork rod to to the max. But that does not help. I don't know what happened? Do I need a longer clutch fork rod? I did not touch the clutch or flywheel. Puzzled... Any suggestions out there?
Did you change the throwout bearing as well while in there? Did you possibly change from a long to short bearing or vice versa by accident?
Did you mount the throw out bearing on the clutch fork properly.
Did you also replace the throw out bearing? There are a few different length ones and you need the correct size to let the system work properly. How much of the rest of the clutch operating assembly was changed?
Discussion Starter #6
Oh yeah... went over it 3 times to make sure I did not do anything stupid. Replaced with the exact bearing.
Discussion Starter #8
I know its a stupid question but if the original worked fine why replace it?
Hi Jerry
Great question... And I failed to specify in the original post. I had to pull the motor to replace the oil pan an gasket. While everything was out, I decided to detail the engine and trans. While removing the clutch fork pivot bolt the clip snapped on the clutch fork. I was reluctant to change the clutch fork, but did not have any other option since there were no markings on the original. I know you can purchase a clutch for spring and rivet, but have no idea how I would press the replacement rivet in.
I don't know the history on the car.... I bought it in August, so anything goes.
Thanks,
Johh
1 - 8 of 8 Posts
