Just installed new flywheel and CenterForce dual friction clutch on my 350 smallblock for my 66 chevelle.Went to bolt up stock bellhousing and Muncie 4 speed with new pilot bushing,clutch fork and throw-out bearing and everything seemed to go together smoothly .But after all the bellhousing bolts were tight the clutch fork wont move and the tranny is in neutral.Do not have z-bar or linkage installed yet.Will this make a difference?Any suggestions guys?Thanks
....Do not have z-bar or linkage installed yet.Will this make a difference?Any suggestions guys?Thanks
No Z-bar linkage??? How are you trying to move the fork then? With your hand? If so, you will only be able to move it about a 1/4" till the TO bearing hits the pressure plate.
