Heres what I am looking for, thanks for the specs. looks like a .123 dome which makes me feel better about the compression limit. I am looking to run pump gas in this. The factory dome was .180 and = 10:25:1 so I am hoping I will be ok with these.
Looking for mild streetable HP
68 396 325 HP with 215 heads
Planning:
.051 over bore (got a deal on .020 over 4.125 bore pistons) with Clevite TC3173 cast pistons with .180 dome, iron rings (not moly of chrome)
.039 head gaskets, no decking or head resurfacing
Summit k1301 218/228* dur @ .050 .500/.500 cam and lifters straight up.
stock intake with 650 cfm edelbrock
stock manifolds
msd hei
Cloyes roller timing set
New bearings all around
stock oil pump
valve seals and or guides
My questions are:
Am I ok for compression ration and pump gas?
Will the cam require a stall (68 SS396 with T400 and 17" wheels, 3:55 rear)?
Scott,
What are your goals for the engine? Here is a link for the specs
http://www.clevite.com/products/Piston Specs.pdf
They run about $30 each, so I hope he would cut you a good deal on them if they fit your needs.
