1 - 10 of 10 Posts
Just received my polished aluminum intake. I was thinking of using some PPG concept clear to keep it from tarnishing. I figure if they do wheels it should work on an Air Gap intake. Any thoughts or experience. I have used that clear on engine blocks after a base coat with no issues.
Research it first. Brass band instruments are coated. Maybe someone in your area offers that service.
· Super Moderator
If it is polished and that is the "look" you want I dont think you will be happy with any type of clear coat in the long run. Every clearcoated intake I have seen ends up looking like crap in a few years. At least if you leave it uncoated you can touch it up with a rag and polish whenever you want.
1970 SS454 LS6 11 second street car
714769
I bought this intake over 20 years ago. I bought it slightly used from a member here on TC. It saw dyno time only,looked as new when I got it. And its never been blasted,I kept it clean with the occasional lacquer thinner wipe down. I probably put over 25K miles on it.
1 - 10 of 10 Posts
