My 396 is sitting on a stand and I want to clean, strip the old paint off of it and repaint it. It is assembled now but I will be adding a stealth intake and a pair of ported "781" casting heads to it so I am mainly conserned with the block and oil pan. I will most likely use wire brushes also. My Questions are:
1. How can I keep old paint shavings from getting into the inside of the engine? Or perhaps stripping the block before swapping the parts is the answer?
2. I may use depending on your suggestions, a cleaner/degreaser to clean the oil off it first. It is not extremely dirty but this will most likely be necessary. Anyway, paint will not stick to the surface if it is not clean and oil free. What type/brand degreaser will give me a good clean surface? I will be using VHT products.
Any other suggestions on this would be most appreciated.
Chris R
Chris R
