Classic car restoration is a very broad term that can mean almost anything, depending who you ask. Deciding what it means to you is crucial to making sure your restoration project goes smoothly and doesn’t end up as a never-finished pile of parts.
Decide exactly what you do and don’t want to do and how far you do and don’t want to go before you start and your restoration will run smoothly. Or at least more smoothly than it will if you don’t.
To help you out with that job, here are 10 things you need to know about classic car restoration and how you can deal with them in the best way.
Lead photo by Dee Dalasio/Shutterstock.com
1. Cut Out the Rust
Rust is number one on the list because rust is the biggest reason for starting a restoration in the first place. If the car wasn’t rusty, you’d just drive it. There are different levels of rust, though, requiring different techniques to get rid of them.
The best way to get rid of rust is to cut out all of the rusty panels. Using a tool like a reciprocating saw, a cut-off wheel, or even, if you’re in a big-budget garage, a plasma cutter that just vaporizes the metal, are the easiest and best ways to cut out the rusty bits.
It’s a bit of a scorched earth policy and you’ll need to use a welder to replace the missing metal, but it will prevent any spread. If a panel is too far gone, many companies sell entire replacements that let you cut out the large piece and replace it all at once.
2. Rust with Less Fuss
If your rust is not through the metal anywhere, there are easier ways to take care of it. A wire brush on a grinder or drill is a quick and easy way to remove rust and scale. Follow it up with a power sander or die grinder to take it back to bare metal and your classic car will be looking good again in no time.
Another way to combat rust is a chemical removal often called Naval Jelly. No, it’s not from your belly button, it is a mix of phosphoric and sulphuric acids in gel form. Brush it on and it chemically transforms light rust into a primable or even paintable surface. Other rust removal products do a similar job to remove light rust.
3. Hold Onto Everything
You are about to remove dozens if not hundreds or even thousands of parts from your car. Lots of those parts are large, but most of them will be tiny. Screws, bolts, nuts, clips, and other fasteners. Losing just one can ruin your entire restoration project. Hold on to them and keep them organized using a parts bin. Offered open or sliding drawers, or even portable tool-box style kits, keeping your hardware sorted and easy to find will save you hours of searching down the road. Having a range of small zip bags you can fasten and then tape to the part they go with is also a great way to go about it.
4. Inside Out
If you’re planning on restoring the interior of your vehicle, and you should, don’t just give everything a vacuum and call it a day. An old car has seen decades of use and abuse including food spills and even worse. Sometimes that means old fabric, leather, and vinyl are not repairable. Replacement seat covers and fabric are available for many vehicles. Same goes for old and tired headliners. To remove the covers from your old seats, you’ll need to remove and replace the steel clips. They’re called hog rings, and using hog ring pliers makes the job more straightforward
5. Engine Management
Some serious parts will need to come out. Like the engine and transmission. To get them out, you’ll need an engine hoist unless you happen to be an Olympic powerlifter. Once the engine is out, an engine stand is the right way to hold the engine in place so you can flip it, add or remove parts, and do everything else that is part of your restoration.
6. Shine That Chrome
Exterior trim that is severely damaged probably needs to be replaced, but thanks to the aftermarket you can probably find everything you need new. Or you can find vintage parts that are in better shape than yours. If your trim is just a little faded and pitted, though, you can restore it quickly and easily. For the easiest items, chrome polish and some elbow grease are enough to bring back the sparkle and get rid of oxidation.
For deeper pits and more damaged finishes, a dual-action polisher is what you need. The spinning and orbiting polishing motion makes quick work of all but the deepest pits, blemishes, and even rust on your original chrome trim. Use that along with a buffing compound designed for metals like chrome and you can bring your old parts back to life.
7. Brakes That Won't Break
Even if your old brake lines aren’t rusted into powder, you’ll probably want to replace them. After all, if you’re doing the work on the rest, why leave one of your most important bits of safety equipment untouched? It gives you the chance to upgrade an old single-cylinder brake system, where one bad line means all your brakes are gone, to a more modern (and safer) dual-circuit system. You could also take the time to install an entire modern braking system. A big brake kit will replace your factory brakes with beefier and newer parts, and you can even replace your old drums with new power discs.
When it comes to making new lines, many older vehicles are actually sold as a complete pre-bent kit. All you need to do with a preformed brake line is bolt it in place and bleed the system. To do it yourself, you’ll need a roll or two of brake line tubing and the appropriate fittings. You’ll need a brake line tube bender to get it to fit into all of the factory locations, but you can usually use the same bender for your fuel lines as well.
Brake lines need to be flared at each end to guarantee that the fittings and line connections won’t leak or come off when you use your brakes. The only way to do this is with a line flaring tool. You’ll also need a brake bleeder kit to get all of the air out of your new lines and the rest of your system.
8. Run the Wires
While wiring will almost always need to be replaced, that doesn’t need to be an impossible task. You’ll probably need some electrical tools like a good multimeter that let you trace wires and find short or open circuits. You’ll also need wiring kits that include your wires as well as relays for the large draws and connectors for everything else. Modern weatherproof connectors are easy to find and affordable. Especially when compared to the alternative. The really easy button is to buy a complete wiring harness kit. These are available for many cars (like these for classic Corvettes) and have everything needed for connectors and wires, all laid out in a way that’s as easy as possible to install.
9. Glass from the Past
Removing your windshield and rear glass is really the only way to make sure that your window frames are rust-free. It’s also the best way to paint your vehicle, because masking around the glass always shows. A windshield removal tool can help you get out that old glass if it’s glued in place. Some vehicles have their glass held in by fasteners that are even easier to remove. Be careful, and use a windshield rack or glass stand to hold the removed glass and avoid shattering it. To reinstall your windshield, use a pro-grade urethane adhesive sealant to make sure that you don’t get rained on while you drive.
10. Paint
Your paintwork might not need anything to be ready for your restoration to be finished, but chances are you have at least some small dings and scratches that need to be addressed. It might be as simple as finding a touch-up paint pen to get those stone chips taken care of, but you might need to strip and repaint completely.
For a complete repaint, you’ll need to strip your car to bare metal. Media blasting, where you use forced air to blast the paint with particles, can take care of most of the paint in the shortest time possible. You can also use sandpaper to remove the paint, starting with a coarse grit (around 60) and then working your way up to around 600. You may need to apply body filler to cover smaller dents, and that can be sanded at up to 2000 grit when dry. Use a sanding block, not your bare hand, or you’ll leave runs and low spots in your metal finish.
Automotive paint is applied using a spray gun and an air compressor. First the primer coat, then the paint, and usually a clear coat that adds shine and gloss. High-grit sanding between coats is an essential part if you’re planning on making your restoration a show car.
Download the eBay Motors App
To make life easier when it comes to getting everything you need for your car or truck, consider downloading the eBay Motors App.
More than just a parts catalog app, the eBay Motors app gives you access to one of the largest selections of parts and accessories in the world. You can also buy and sell vehicles and connect directly with automotive enthusiasts right from your phone.
Take advantage of the My Garage feature to easily store your vehicle’s specs so you can quickly find and buy the parts you want. You can store multiple vehicles in your profile, which means you don’t have to re-input the same information every time you use the app. Plus, eBay’s fitment feature ensures you will find the parts that will fit your vehicle.
Another great feature on the app for vehicle sellers is the ability to upload a picture of your license plate, which eBay then uses to grab all the pertinent details of your vehicle for selling, including uploading your VIN number.
Download the eBay Motors app today.
We are committed to finding, researching, and recommending the best products. We earn commissions from purchases you make using the retail links in our product reviews. Learn more about how this works.
