1 - 13 of 13 Posts
I have a '69 Malibu with the following:
1984 GMC 461 with stock compression
Stock peanut port heads
Isky 270 hydraulic flat tappet cam, .510/.510, 216/216, 114
Recurved GM HEI
High-rise intake
Edelbrock 1806 650 cfm AVS carb
TH-400 with 1800 stall
Headers
3" exhaust, 2 1/2" over diff, 3" tail pipes
12-bolt 2.73 open
27" rear tires
This is a daily driver which is why I have 2.73 gears. It still has plenty of SOTP oomf. I'm going to go with a posi, which isn't available with new 2.73's. The next step up numerically is 3.07, which would also work fine as the car use to have a 9" rear end with 3.00's.
I've been reading posts about how some guys have found no decrease in mpg, and in some cases a slight increase, when they went to a numerically higher gear. They attribute it to the mildly steeper gears bringing the engine up to its cruise rpm, making it more efficient. This cam's rpm range is 2000-6000. Presently, the engine turns about 2250 prms at 65 mph. With 3.07's, it would turn about 2550. With 2.73's, the car is getting about 14-15 mpg on the highway.
Where is the cruise rpm for a cam like this? Should I go as far as a 3.23? (about 2700 rpm's at 65 mph)
Thanks for any advice.
i would suggest the 3.07-.08 for a driver car. any more w/o o/d and it will certainly hurt mileage. tom
3.07 should be good with you engine combo. The most I'd go is 3:55's.
I'm leaning towards 3.07's, but If I would go to 3.23's for that extra SOTP power, would it decrease my mileage that much, or would I be in the cam's "sweet spot" without hurting my mileage? Has anyone tried this?
How about the SOTP difference between 3.07's and 3.23? SOTP is impossible to quantify, but I'd be willing to sacrifice ~5% of mileage for a noticeable boost in power. Anyone done the switch from 3.07's to 3.23's?
Thanks, Webfoot. I'll probably go with the 3.07's. In a blind taste test, I'd probably never know the difference. It'll be nice to have posi, though. With the peg-leg, I've got to ease the pedal down or she'll just spin for a good 3 or 4 seconds. I'm sure it'll be much faster off the line with just the increased traction.
I think you'll notice a snappier throttle just going from 2.73's to 3.07's. I have 3.08's in my Camaro with a posi and 4 speed and power is excellent. It dosent pull rpm's like my Beamont with 3.73's but I had to go with a TKO600 to get the highway rpms down. I still haven't fiqured out what SOTP means!
I only have limited mileage on the new combo, but going from a 3.08 to a 4.10 was an incredible SOTP improvement...doesn't hurt that it's a posi now also.
I realize mine is more like a 30 % increase in gear, but I'm sure you'd notice a real kick in the butt going from 2.73's to 3.23's, which is about an 18% increase in gear I think.:thumbsup:
SOTP...seat of the pants
1 - 13 of 13 Posts
