1 - 19 of 19 Posts
I have a 70 454 Chevelle LS-5 with posi rear-end. When i press the accellerator the car torques/pitches to the left, and when I let off the accellerator, the car "releases" and torques/pitches back to the right. It is as if one set of wheels is turning faster than the other. I am thinking it may be a rear-end issue, but I don't don't know for sure. Anyone ever heard of this or have any ideas? Thanks!
Check your motor mounts, you may have a broken one. I doubt it is a rear end issue unless you can feel it breaking loose.
i think a car will do that when the posi clutches are wearing out- one tire is spinning slightly faster than the other, causing the car to get slideways.
Broken axle?
rear left brake assembly... something getting wedged ?? Not the same scenario, but I had frozen calipers in my Pickup. Pulled like the devil to one side..
I had that exact symtom once. It wound up being a damaged rear control arm.
Same here.
Didnt notice it until I went to pull them out and install the hotchkis arms and then got the "ah, well that would explain it" moment.
I had this happen to me. It was a bolt on the upper left control arm(rear, of course) had fallen out. That was bad enough. Sure glad it was not a lower control arm!
I should of mentioned that it was my upper left that was fragged. Cracked and bent just near the rear pumpkin. Still had a bolt through it, just didnt matter much. :D
My first thought was the clutches in the posi are slipping as well.
Broken axle?
the first symptom of a broken axle would be when the tire and what's left of the axle passes the car when you get on it..
Same symptom,but frame crossmember tearing apart near left rear upper cntrl arm mount.
So did you ever figure out the problem Scott?
1 - 19 of 19 Posts
