Maybe someone can help me. I am a current owner of a 1967 Chevelle SS - (original 396 car) now with a (in question) 427 NOM
installed. The car is a true SS, however, the motor is where my trouble is.
The car has been fully restored with a complete rebuild on the "427".
However, I don't know much about the motor at all. And the more I try to
find out, the more questions I have.
I was told when I purchased the car that the engine was a 1969 427 out of an
Impala w/rec. port heads. Okay - but when I pulled off the aluminum GM
hi-rise manifold I discovered that the manifold was for rec. port heads and
that the "427" had oval port heads.
Next, I started getting the block numbers (something I guess I should of
done in the first place), and this is what I found out:
VIN# 138177A110553 (at least I know that it's a 1381 car)
Here's where it gets interesting:
Engine ID = 1237971 T0323LC
(which matches to a 1969 427/390 Impala motor w/auto tranny)
Casting # 3855961
(which checks to be a 1966-67 396/325 or 360 2-bolt motor)
It doesn't seem to match.
Any help in determine what's going on here would be truly appreciated!
Casting # 3855961
