when I got to start my car in the morning, my voltometer reads about 10.5 volts. but the car fires right up.
then after driving on the freeway for a min or two the voltometer slowing creeps up to 17.5 volts.
it stays that high unless I turn on my stereoor electric fans. the fans cut it down to about 15volts and the amps for my stereo cut it down under 14 when the woofers hit.
I can watch my voltometer bouce from 17 to 14 whith the beat from the woofers.
is this normal?
do I need a bigger battery?
is my alternator bad?(had it checked at kragen they said it was good)
anyone have any Idea of what would cause this?
thanks
Justin McIver
Sacramento CA
66-454-th350
is this normal?
thanks
Justin McIver
Sacramento CA
66-454-th350
