I am having a charging problem with my 68 SS396. When the engine is running the voltmeter is running around 11.8 volts. When the blinkers go on (or anything for that matter) the gauge dips below that. I've replaced the alternator, horn relay, voltage regulator, battery cables and various old wires. The battery holds a charge and starts the car just fine as long as I don't run the headlights or take long drives. I've searched and read many messages on this forum and ran some of the tests. Here are the results:
1. Removed the plug from the regulator and turned ignition on and engine off. Measured the brown wire to a ground and had 12.75 volts.
2. Put connector back on and removed plug from alternator. With key on and engine off, the blue wire to a ground showed 12.35 volts.
These tests were done with key on and engine off at the voltage regulator:
F terminal at alternator = 11.50 volts
#2 terminal = 0 volts
#3 terminal = 13.02 volts
#4 terminal = 11.5 volts
I cannot test with engine on until I replace the bendix in the starter. But I did test it awhile back and got a little under 12 volts at alternator red wire with about 1000 rpm's. I've also checked with a ohm meter the continuity of each wire and got 0 ohms which means the wires are okay? The alternator was tested a couple of times (first when bought and once I took it back) and it tested just fine on their machine. Like I said earlier, I can't do the alternator flash test until I get her to run. Does anyone have any ideas what the problem could be? The wiring seems fine and still points to the alternator not kicking on but the machine kicks it just fine!? I'm at wits end with this SOB. What can I do next????
Thanks,
Gary
Thanks,
Gary
