1 - 8 of 8 Posts
My battery is not charging and my generator light is on in the car. This is the third time I have had this problem in the last year. I have replaced the alternator and voltage regulator twice, and it seems to be solved each time. I just replaced them both a little over a month ago, and the battery started cherging. Then a day later the gen light came back on, and it wasnt charging. The next day when I put the car into park, the light went out and the car was fine. The light has now been on for about a week and it is not charging. Does anyone know what would be causing this problem? Could it be wiring? How would I check this? Could an alternator with an internal regulator solve the problem?
Did you check the distilled water level in all the battery cells? You most probably have, but sometimes you forget the obvious. Been there, done that. :D
Olli
The battery is good. The car starts, but it is slowly dying as the battery is not being charged.
I think I have the solution for you.
I had the smae problem with my 70 and 71. I rewired it to bypass the external voltage regulator and I went with an altenator w/an internal regulator. I still drive the car to this day and haven't had that problem since. Here are a couple photos to show you what I mean.
My 71's battery was tested only to find that it had a bad cell in it. But I rewired it to rid my headaches for good.
can you just disconnect the voltage regulator and buy the adaptor harness for the new alternator, or do you need to rewire everything
1 - 8 of 8 Posts
