Is there any trick to runing the wires through the door jam? The wiring harness that came wit the window motors looks like it has 3 hole plugs so not sure what size holes to make and where to make them.
Thanks.
Daniel
i have a 65 with factory power windows. you can buy reproduction power window wiring boots thru any of the repop catalogs. they fit excellent. just use a hole saw to drill the holes in the door,door jamb and the inside of the jam. you should be able to measure the boot to find what hole size . good luck.
Discussion Starter #3
Thanks! Would you be able to tell me where on your doors the hole is made?
there should be a dimple in the front of the door and a corresponding dimple in the side of the cowl roughly half way between the hinges. my elcamino has the dimples in the same spot as my power window boots an my chevelle.
