I have a Ramjet 502 with a fairly big street cam.Compression is
8.9-1.Hooker headers into 3" pipes to mufflers just over the axle and then into 3 1/2" tailpipes to bumper.The mufflers were 3" Pro Flows.This combo was loud and had that ratatat machine gun sound.I hated it.We changed the mufflers to Magnaflow 3" #17744.Centre in offset out.These mufflers actually neck down to 2 1/2" inside.I was hoping this would make them even quieter.My muffler guy said that because the mufflers were not marked as to there in or out pipe you could put them on either way.We installed themwith offset in and centre out (backwards).We also added a H pipe.The car sounds much better but it is not much quieter on the outside.On the inside it is quite reasonable.
I'd like to quiet it down on the outside and was considering adding a pair of bullet style mufflers or resonators.I was also considering changing the tailpipes to 3" but I'm not sure 1/2" will make much of a difference.I don't mind giving up some HP to gain a quieter car.I'm just going to open the headers at the track to make all the power.
What do you think?
What do you think?
