How much change should I see if any over the old torker that I'm currently running.Was given one of the edelbrock top end kits and thought i might try the intake on current setup.454,summit 1302 cam, 290 heads,750 eddy.
Twisted style.Don't know height difference by chance do you .Haven't measured yet but doesn't look like much if any.
I think the best indicator Mike is that if the Torker was a better intake everyone would still be runnimg them. The Airgap is very good, you should see some bottom end pick up with your combo...JMO...
Bet it out performs the Torker everywhere, at least to 5500.
Like those old intakes but whats out now is just better.
Port the RPM and it will be that much better, had good luck with those.
