i have a 454 in my 72 velle and im trying to figure out if it was a good casting the numbers i pulled where 861859 but it might also be 361959 i also got T0609TSF from the front of the block any info would be help full. ive tried searching it and mortec wasnt that helpfull
TSF 78 454 Truck 250 LF-8 Manual 4-Brl C-20 & C-30
361959 454 73-85 Car & Truck
Is this about the same thing you found?
As long as the block is rebuildable(not already bored .060 or more) you have a keeper. It's possibly a 4 bolt, look at the oil filter housing and see what size pipe fittings are there. It's not a for sure check but it can give good clues without tearing the pan off.
