Any ideas how to remove the pipe fittings for the heater hoses etc from a 38 year old cast iron manifold?
While it is off I want to replace them. Been soaking them with wd40 but no luck yet
Try to tighten them just a little bit to break them loose. Fire wrench comes next if the first suggestion doesn't work.
After struggling I used alittle heat.....came right off.
I drove a bolt into the by pass fitting to let me use a pipe wrench and it not collapse.
