i have one in my malibu, and for the one day i had my car on the road last year it was fine. not much help here BUT on my camaro i had a 4070 fuel pump. i got it from my friend for free in a well used condition. it was atleast 15 years old when i got it. it work flawlessly. it propled my 400 sbc power camaro to a 13.001. and the 4070 fuel pump dosnt flow as much as the 4600. i would say that there pretty reliable
I have one. I like it....been good to me for the last 4-5 years. Not a lick of trouble. I too had a lot of problems with the holley blue's I was using before that. They'd only last about 1-2 years before they died.
Also, running any pump dead-headed will shorten its life, and make more noise than using a return line and regualtor. Even though Holley recommends using their dead--head regulator when using a blue pump, the pumps don't like it. A blue pump doesn't make the most sense, if you don't need the flow it produces. It will run constantly at full load, banging away at the 14psi internal relief valve. A return regualtor will allow the pump to run at whatever you set for the carb pressure, somewhere around 7psi. This lightens the load on the pump, and it'll run quieter and cooler. (most likly longer too....)
So, my 8psi carter, with a return line, runs at 6psi where I set it. It's been very reliable for me, and is MUCH quieter than the Holley's....
