454 in my 69 carbons up the plugs in 10 min of running, why so quick? New distributer, timing at 12 degrees advace. New 44 AC plugs and wires, rebuilt carb. Car runs ruff. Could the dizzy be off a tooth or???
Vacuum advance ?The Accel distributer, complete is brand new.
????? Does the VA mean vacuum advance ? You are using it with the carb number and that is confusing. If you do have vacuum advance where is the hose connected to ? Straight manifold vacuum or ported vacuum ? What does the timing go up to when you connect the vacuum advance ?Check #8, does have vac advance.
