List the whole combo if you would...including timing, vacuum #'s if you have them.
1973 vintage 2-bolt 454 block, bored .060 and align honed
Balanced rotating assembly from Mike Lewis (Wolfplace) – SCAT forged crank, h-beam rods, SRP forged pistons
Moroso 20451 7-qt oil pan with Moroso pump & pickup
GM 781 casting heads, modified with 2.19/1.88 valves, otherwise as-cast (no porting)
Isky hydraulic roller cam (thanks to Mark/VORTECPRO) #396275/284
228/238 @ .050, lift .553/.578, 112 LSA, installed at 109
Isky lifters & springs
Manley pushrods
Comp Pro Magnum roller rockers, 1.7 ratio
Edelbrock Performer RPM 2.0
Holley #4779 750 double pumper
MSD Pro Billet distributor with MSD 6AL
Carter 172 fuel pump with -8 AN line from tank to carb
Summit headers, 1.75” primaries, 3.00” collectors, 2.5" muflers/tailpipes
TH400 with Coan 11” converter, stall 2400-2800
3.42 rear gears
Mechanical timing is 16* initial, 36* total. I am also using vacuum advance, but haven't measured how much advance the vacuum canister is adding. I have not measured idle vacuum either, but this can idles very smooth, so I'm sure the vacuul numbers would be fairly high.
