Can anyone help me with a stupid question. I have basically a stock 454 bored .30 over with a mild cam (sorry don't know the specifics) Edlelbrock performer intake, HEI ignition and a Holley 750 Double pumper manual choke with mechanical secondaries, (4 speed borg & Warner T10) It runs good, but the exhaust smells very rich at idle and almost unbeareble when I really get on it. I tried adjusting the air fuel mixture and found the screws have to be almost all the way in, in fact they're only out about 1/4 of a turn, If they're out any further in fourth gear it wants to die. I checked the timing it is right on. Also when cold I can't use the manual choke if it's on at all the motor immediately dies, and as you can imagine, when it's cold it doesn't want to run without the choke either. Basically I am wondering if the carb is too big, maybe the wrong jets or do I just live with the strong exhaust? Any help is appreciated. Also what suggestions would you have on a replacement carb?
